(Danatronics: Danvers, MA) -- Danatronics, developer and manufacturer of ultrasonic testing equipment, announces the ECHO FD, a handheld, digital, ultrasonic flaw detector. ECHO FD is extremely affordable, light weight, and easy to use. It is equipped with a 3.5-in. sunlight readable color display, peak memory, two independent gates, DAC curves, AWS software, and standard 2 GB micro sd card memory.
ECHO FD has a fast 60 Hz display update rate and an on-board re-chargeable battery in a custom case designed for IP67 with rubber boot and stand. ECHO FD can use a wide variety of transducers from 1-20 Mhz in contact, delay line, duals, immersion, and angle beam for your flaw detection applications. ECHO FD is proudly designed and made in the USA.
For more information, call, click, or write to (978) 777-0081, www.danatronics.com, or sales@danatronics.com.
