Dimensional Metrology Standards Consortium  |  10/19/2009
Dimensional Metrology Standards Consortium’s default image
Product News: DMIS Output Tools by CMM Technology Solutions
Now available from the DMSC Online Store
(Dimensional Metrology Standards Consortium: Arlington, TX) -- The new DMIS Output Tools are inexpensive and easy-to-use reporting tools. The DMIS Output Tools application offers a simple set of data reporting and export capabilities based on standard DMIS output files.
Its key features include:
  • No proprietary results database.
  • No data parsing from unreliable result listings.
  • Available feature coordinate data (not just toleranced output).
  • Result summary.
  • Single run reports.
  • Statistics reports.
  • Data export capabilities.
Result summary:
The summary function gives you a quick view of the overall result picture for the selected output file and provides access to each result in summary form. A drop-down list shows all results and their error status.
Single-run reports:
The single-run reports provide text and scale-based output showing various views of the results. The summary preview shows actual, nominal, and deviation text along with the amount of tolerance used, in the form of scales and text. The short- and full-text reports are similar to the classic coordinate measurement machine (CMM) report but allow more configuration options with regard to the content and format. All text reports are available directly from the applications interface or via the command line, allowing users to automate printing of reports after inspection.
Statistics reports:
The statistics reports provide simple feedback regarding the state of the manufacturing process without the need for complex parsing and database storage. Just select the output files you would like to examine and get a preview of the relevant statistics report (X bar and R, X bar and S, individual and moving range, and median).
Result export:
Results can be saved to other files in a variety of formats using the result export dialog. The dialog provides control over the content and format of the data that will be saved and can be used in single run or historical mode from the application interface or command line.
For more information, contact Bailey Squier, bsquier@dmisstandard.org.
To order, click here.
The mission of the Dimensional Metrology Standards Consortium Inc. (DMSC) is to identify urgently needed standards in the field of dimensional metrology, and to promote, foster, and encourage the development and interoperability of these standards, along with related and supporting standards that will benefit the industry as a whole. The Dimensional Measuring Interface Standard (DMIS) is one such standard that the consortium has the responsibility to develop, maintain, and support as well as to coordinate and harmonize with other related standards efforts.
  • Classifieds
  • File Share
  • Forum Topic
  • Events
  • Links
Sign In to get started!
Quality Information
