Featured Video
Innovation Features
Tom Scaletta
Timely, objective, patient-specific comments and data can help physicians enhance patient satisfaction
Taran March @ Quality Digest
Out of step and out of luck with Industry 4.0
Jeffrey Phillips
Three simple rules to distinguish innovation from business as usual
Jean-Noel Barrot
Reducing payment times from 30 days to 15 days can have a significant positive effect
Paul Blanchard
New technology examines materials one atom at a time
More Features
Innovation News
Study finds law-breaking property that could lead to applications in thermoelectrics, window coatings
Three phases and challenges
By 2025, four levels of self-learning technology will be in play
Automaker’s decision marks reversal on plans to build new plant in Mexico
Mechanical engineer builds animal-like machines for use in disaster response
New company will focus on technologies for the management and automation of vital clinical processes
Executive survey uses IBM’s Watson to measure CEO engagement with quality improvement in manufacturing
More News
  • SUBSCRIBE
Innovation
Data’s Best Friend
Turning diamond defects into long-term 3D data storage
Published: Tuesday, December 6, 2016 - 15:52
With the amount of data storage required for our daily lives growing, and available technology becoming saturated, we’re in desparate need of a new method of data storage.
The standard magnetic hard disk drive (HDD)—like what’s probably in your laptop computer—has reached its limit, holding a maximum of a few terabytes. Standard optical disk technologies, like compact disc (CD), digital video disc (DVD) and Blu-ray disc, are restricted by their two-dimensional nature—they just store data in one plane—and also by a physical law called the diffraction limit, based on the wavelength of light, which constrains our ability to focus light to a very small volume.
And then there’s the lifetime of the memory itself to consider. HDDs, as we’ve all experienced in our personal lives, may last only a few years before things start to behave strangely or just fail outright. DVDs and similar media are advertised as having a storage lifetime of hundreds of years. In practice this may be cut down to a few decades, assuming the disk is not rewritable. Rewritable disks degrade on each rewrite.
Without better solutions, we face financial and technological disruptions as our current storage media reach their limits. How can we store large amounts of data in a way that’s secure for a long time and can be reused or recycled?
In our lab, we’re experimenting with a perhaps unexpected memory material you may even be wearing on your ring finger right now: diamond. On the atomic level, these crystals are extremely orderly, but sometimes defects arise. We’re exploiting these defects as a possible way to store information in three dimensions.
Focusing on tiny defects
One approach to improving data storage has been to continue in the direction of optical memory, but extend it to multiple dimensions. Instead of writing the data to a surface, write it to a volume; i.e., make your bits three-dimensional. The data are still limited by the physical inability to focus light to a very small space, but you now have access to an additional dimension in which to store the data. Some methods also polarize the light, giving you even more dimensions for data storage. However, most of these methods are not rewritable.
Here’s where diamonds come in.
Figure 1: The orderly structure of a diamond, but with a vacancy and a nitrogen atom replacing two of the carbon atoms
A diamond is supposed to be a pure, well-ordered array of carbon atoms. Under an electron microscope, it usually looks like a neatly arranged 3D lattice. But occasionally there is a break in the order, and a carbon atom is missing. This is what is known as a vacancy. Further tainting the diamond, a nitrogen atom sometimes will take the place of a carbon atom. When a vacancy and a nitrogen atom are next to each other, the composite defect is called a nitrogen vacancy (NV) center. These types of defects are always present to some degree, even in natural diamonds. In large concentrations, NV centers can impart a characteristic red color to the diamond that contains them.
This defect is having a huge effect in physics and chemistry right now. Researchers have used it to detect the unique nuclear magnetic resonance signatures of single proteins and are probing it in a variety of quantum mechanical experiments.
NV centers have a tendency to trap electrons, but the electron can also be forced out of the defect by a laser pulse. For many researchers, the defects are interesting only when they’re holding on to electrons. So for them, the fact that the defects can release the electrons, too, is a problem.
But in our lab, we instead look at these NV centers as a potential benefit. We think of each one as a nanoscopic “bit.” If the defect has an extra electron, the bit is a one. If it doesn’t have an extra electron, the bit is a zero. This electron yes/no, on/off, one/zero property opens the door for turning the NV center’s charge state into the basis for using diamonds as a long-term storage medium.
Figure 2: Starting from a blank ensemble of NV centers in a diamond (1), information can be written (2), erased (3), and rewritten (4).
Turning the defect into a benefit
Previous experiments with this defect have demonstrated some properties that make diamond a good candidate for a memory platform.
First, researchers can selectively change the charge state of an individual defect so it either holds an electron or not. We’ve used a green laser pulse to assist in trapping an electron and a high-power red laser pulse to eject an electron from the defect. A low-power red laser pulse can help check if an electron is trapped or not. If left completely in the dark, the defects maintain their charged/discharged status virtually forever.
Figure 3: The NV centers can encode data on various levels.
Our method is still diffraction-limited, but it’s 3D in the sense that we can charge and discharge the defects at any point inside of the diamond. We also present a sort of fourth dimension. Because the defects are so small and our laser is diffraction-limited, we are technically charging and discharging many defects in a single pulse. By varying the duration of the laser pulse in a single region, we can control the number of charged NV centers and consequently encode multiple bits of information.
Although one could use natural diamonds for these applications, we use artificially lab-grown diamonds. That way we can efficiently control the concentration of nitrogen vacancy centers in the diamond.
All these improvements add up to about 100 times enhancement in terms of bit density relative to the current DVD technology. That means we can encode all the information from a DVD into a diamond that takes up about 1 percent of the space.
Beyond charge, to spin
If we could get beyond the diffraction limit of light, we could improve storage capacities even further. We have one novel proposal on this front.
Figure 4: A human cell, imaged on the right with super-resolution microscope.
NV centers have also been used in the execution of what is called super-resolution microscopy to image things that are much smaller than the wavelength of light. However, since the super-resolution technique works on the same principles of charging and discharging the defect, it will cause unintentional alteration in the pattern that one wants to encode. Therefore, we won’t be able to use it as it is for memory storage application, and we’d need to back up the already written data somehow during a read or write step.
Here we propose the idea of what we call “charge-to-spin conversion”; we temporarily encode the charge state of the defect in the spin state of the defect’s host nitrogen nucleus. Spin is a fundamental property of any elementary particle; it’s similar to its charge, and can be imagined as having a very tiny magnet permanently attached to it.
While the charges are being adjusted to read/write the information as desired, the previously written information is well protected in the nitrogen spin state. Once the charges have encoded, the information can be back-converted from the nitrogen spin to the charge state through another mechanism we call “spin-to-charge conversion.”
With these advanced protocols, the storage capacity of a diamond would surpass what existing technologies can achieve. This is just a beginning, but these initial results give us a potential way of storing a huge amount of data in a brand-new way. We’re looking forward to transforming this beautiful quirk of physics into a vastly useful technology.
This article was originally published on The Conversation. Read the original article.
About The Authors
Siddharth Dhomkar’s picture
Siddharth Dhomkar
Siddharth Dhomkar is an experimental physicist interested in exploring fundamental properties of defects in wide band gap semiconductors. He is a post-doctoral associate at the City College of New York, CUNY.
Jacob Henshaw’s picture
Jacob Henshaw
Jacob Henshaw is a forth year Ph.D. student at CUNY-Graduate Center working at City college of New York. He did his undergraduate studies at Indiana University in Bloomington,Indiana, where he worked as a Research Consultant at Procure and Pronova Solutions helping develop new technology for cancer therapy.
He is currently working in the Meriles Group at City College of New York. His research interests are quantum information processing, quantum control, and spin dynamics.
