Slow monitors that don’t pick up the exact end-point when a part is seated properly can hamper high-volume press-fitting operations. This process-control problem is especially widespread in automotive-powertrain assembly. A transmission, transfer case or differential can contain four to six bearings that are press-fit into place on an assembly line turning out 3,000 transmissions a day. Press fits are also widely found in assembly or rebuilding of turbomachinery, aircraft, industrial machinery, motion-control systems and precision medical devices.
Privacy Policy.
