One specialist in this area is EyePro System, located in northern Italy. Established in 1999, EyePro System is a spin-off of ITC-irst, an Italian research center working in the field of image processing, speech recognition, and microelectronics. The company combines the diverse talents and experience of its founders in a range of activities, from performing research in computer science, statistical data analysis, pattern recognition, and image processing to engineering automated systems for industrial inspection, control, and measurement applications.
