(Siemens: Munich) -- At the upcoming IMTS 2024 in Chicago, September 9–14, Siemens will present its extensive machine tool CNC portfolio and digitalization software technology, highlighted by the digital native SINUMERIK ONE control platform for machining applications.
Using a sports theme of “Speed, Agility and Endurance,” aimed at the machine shop on its path to digitalization, Siemens will also introduce MACHINUM to the North American market. MACHINUM brings together machine tool controls, digitalization software, and machine shop services from Siemens to help manufacturers optimize their production processes. The system provides agility for quick adaptation to changing customer requirements and calculated uptime needs, plus enables digitally proven endurance to maximize the productivity of the entire machine shop or production department.
The elements of MACHINUM include:
Speed
Siemens adaptive feed-rate control reduces cycle times while maintaining a stable machining process. This results from instantaneous and continuous analysis of the current cutting conditions on a machine tool in real time, automatically optimizing the feed rate.
Agility
Through strategic digitalization and software that integrates the machine tool CNC systems and a shop’s internal communications, MACHINUM can significantly boost the agility of a machine shop or production department to accommodate changes in design, quantity output, and even machining characteristics, all based on customer input, overall production, and workflow characteristics.
Endurance
Continuing the sports theme over the long run, MACHINUM enables a heightened level of maintenance capability with leading-edge machine monitoring that anticipates potential issues before they escalate. This results in reduced cost and substantially less downtime due to unplanned maintenance on machines. This feature is especially useful for linked and sequential production lines.
MACHINUM also offers substantial benefits to machine builders because Siemens’ integrated digital twin technology allows more streamlined off-machine programming and machining simulation in an office environment. This approach facilitates faster prep time; more accurate design specs on the final machine; faster component acquisition near the build time; and a reduction in costly downtime due to last-minute design changes, since those are anticipated, simulated, and resolved, all in a virtual world. MACHINUM also represents the integration of existing Siemens digitalization software such as Create MyVirtual Machine, Run MyVirtual Machine, Adaptive Control and Monitoring (ACM), Analyze MyWorkpiece, and Manage MyMachines.
Under the theme “Empowering the Digital Machine Shop,” Siemens will display its digital threads, from blueprint to finished part, digital twin to simulation, part production, and integrating these processes into the digital factory. It’s all brought to life by Siemens hardware automation and digitalization software.
eRod continues its path
Building off the successful rollout of its eRod “electric buggy” at IMTS 2022, Siemens will further demonstrate the end-to-end production of the aluminum wheel rim and gear housing for this electric vehicle on display in the booth. The wheel rim is made by traditional 5-axis and multitechnology machining (mill-turn, turn-mill), and the gear housing is manufactured through additive/subtractive machining processes.
At every stage of each part’s development, displays will take visitors through the digital manufacturing process. From the Siemens NX CAM software, which enables the use of 3D models, data, and processes to seamlessly connect planning and shop floor operations, to SINUMERIK ONE, the digital-native CNC that permits a digital twin of the machine tool and its full operation in production, Siemens has streamlined machine shop operations as well as leading automotive, aerospace, off-highway, medical part, and myriad consumer durable production facilities worldwide.
Additional highlights of the Siemens booth
Aimed at developing a complete ecosystem for the machine tool builder and end user, the Siemens Xcelerator portfolio brings together the breadth of engineering and manufacturing to provide the optimum solution for customers of any size in any industry.
Digitalization solutions will shorten the machine tool builder’s time to market through digital twin technology, where all machine design and operational kinematics are simulated prior to the machine being built. This development enables substantial savings for the builder and end user alike, not only in the design, building, and commissioning, but also during the startup and training phases of machine implementation.
With SINUMERIK ONE, Siemens is accelerating the digital transformation of the machine tool industry. The new CNC control platform works with software to create the machine controller and the associated digital twin from a single engineering system, and thus contributes to the total integration of hardware and software. Thanks to its seamless interaction between the virtual and real worlds, including high-performance PLC, drive, and motor hardware, SINUMERIK ONE is setting new standards in productivity, performance, and digitalization.
With Create MyVirtual Machine and Run MyVirtual Machine, SINUMERIK ONE is provided with software to create the universal concept of the digital twin, powerful hardware, and integrated IT security, making it a forward-looking CNC.
Using Mcenter, the open and modular platform for efficient shop floors, end users can seamlessly link all their machine tools and network with their company’s IT landscape.
Finally, in a fun highlight at this year’s show, Siemens will hold a golf putting contest and raffle two putters twice daily during IMTS 2024. The putter heads will be machined using Siemens CNC hardware automation and digitalization software, and feature custom engraving.
For more information about Siemens at IMTS 2024, visit: https://usa.siemens.com/imts.
For more information about the new MACHINUM portfolio, visit: https://usa.siemens.com/machinum.
Siemens will display the eRod, an autonomous electric vehicle, to demonstrate the complete production of the aluminum wheel rims and gear housing.
