Miriam Boudreaux  |  02/08/2010
Miriam Boudreaux’s picture
The Truth About Sales and Quality
ISO 9001 and other quality initiatives can improve your processes, but can they also improve your sales?
When a quality management system (QMS) is implemented, results are evident immediately: reduction in warranty cost, reduction in rework, reduction in scrap, higher profit margins, etc. Would you agree that ISO  9001 and other quality initiatives such as lean, Six Sigma, and 5S can significantly improve any company’s processes—if requirements are correctly implemented? Why, if you know that a good quality management system improves your processes, are you reluctant to include all company processes in this system? Why would most companies barely include sales on any quality initiatives? If and only if you apply the same ISO quality standards and quality concepts to the entire sales process, inside and outside sales, you stand to see significant improvements.
The truth about sales and quality
For most companies, there are two distinctive sales areas: inside sales and outside sales. Inside sales is typically the area where customer requirements are met. Therefore, inside sales tends to get more face time with ISO 9001. However, outside sales usually gets less thought with regard to the QMS or gets left out. In fact, unless there is no other department handling customer requirements, they usually get a pass when it comes to implementing ISO 9001.
If we know that ISO 9001 and other QMSs improve processes, why are outside sales and inside sales rarely included in the QMS?
Most companies just don’t think of sales as anything that can be improved using the same principles, insofar as obtaining customer requirements. Perhaps they think of sales as an art and as something better left to the sales experts. However, every time quality managers leave sales out of a QMS, they are then gambling with the company’s profits and leaving the process in the hands of the sales experts alone.
ISO 9001's effect on sales
Although an argument could be made that ISO 9001 indirectly affects sales as a whole, we can only truthfully narrow the direct positive effect to a few areas. The table below provides a list of key ISO 9001 requirements and their ultimate effect on sales.
ISO/Quality RequirementPurposeEffect in operationsEffect On sales
Quality policySet company directionIncrease employee’s pride
Quality manualSummary of processes and proceduresBetter presentation of processesShowcase of company processes
External auditsMonitor QMS and keep certificationEliminate deviations and promote adherence to policies and procedures
Maintain orders or obtain new orders from customers who require ISO 9001
Focus on customer satisfactionMonitor customer satisfactionMake decisions to support improvementsIncrease in repetitive business
Tracking objectivesMonitor QMS performanceImprove efficiency of processesIncrease profit margins
ProceduresNormalize processesImprove consistency and reduce process errorsIncrease profit margins
Corrective and preventive actionCorrect or prevent systemic issuesImprove overall processDecrease customer returns or complaints
Mapping the sales process
So are you ready to include your outside sales processes in your product realization processes? The first thing you need to do is map your processes. Here is a good example of what a simple sales process may look like. The inputs and the outputs are depicted in black. The outside sales process steps are depicted in blue. The arrows show the sequence and interaction. In this case we are assuming the process happens in a straight line.
The benefits of a straight line is that you are forcing the process to go a certain way, and although adjustments may be made if you get the contract after the inquiry handling step, the idea of mapping the process is that you do not submit a proposal unless you have conducted a presentation—and not after the first inquiry handling step.
In order to explain this better, let's look at each step in detail. This will help you create a robust procedure for your sales process.
Inquiry handling. Here you can explain what you expect to be said upon receipt of a call or how you expect to answer an e-mail.  Obviously every case is different and every customer is different, however having some guidelines will help even the receptionist become a good sales call handler. Here are a couple of things you can also prepare:
  • Scripts: Prepare scripts for answering calls by product or service type or for answering e-mails.
  • Forms: Prepare forms that can be filled out by anybody who is receiving a call, such as an inquiry form, pre-quote, etc.
Presentation. Depending on what kind of sales you do, presentation will most of the time work to your advantage. So this step should allow for either face-to-face presentations or online presentations. In either case you can let each sales person do some customization, however, having a consistent and basic presentation is key to ensuring everyone will show what is considered important.
Proposal. This step should provides guidelines for providing a good proposal. Of course, templates will also be necessary to ensure that your sales team looks professional. Even if you submit proposals as part of an e-mail, having a template will help maintain consistency.
Closing. Follow-up in the form of e-mails, phone calls, and so forth could be covered in this step. You could also implement logs to keep track of follow-ups. Of course if you own a sales software package, then the software should help you keep track of the follow-up steps.
Benefits to Expect
The following chart shows the benefits that you should see after mapping and defining each step of the sales process.
For example if you look at the Presentation step, one of the benefits you should see after formalizing this process is improved consistency among sales personnel, improved confidence by sales employees that the presentation is true and tested, and finally an improved understanding by the customer of your organization's products and services.
Quality objectives
Ok, we all have something like "we need to increase sales by 50 percent," and we all know that is not exactly a quality objective. So what could be a quality objective for the sales department? Well, once you have mapped the process and outlined the procedure and created any associated form and templates, you need to set up objectives to help you measure if your sales process is actually performing well.
Here are a few sample objectives that could go with the process above:
  • Proposal turnaround time: e.g., 15 days from inquiry
  • Presentation turnaround time: e.g., Seven days from inquiry
  • Decrease proposal errors: e.g., Zero changes on the proposal due to wrong or misinterpreted requirements
  • Improve rate of inquiries to presentations: e.g., 90 percent of inquiries handled translate into quotes
Yes, some of these metrics will make your sales team work hard, but isn't that every employee's duty, to work hard in order to achieve their goals? Also, no, you should not have to hire a new employee just to keep up with your metrics. So define the metrics that apply to your company, measure what means most to you, and concentrate on what can actually improve your sales process.
Include sales in your product realization processes
When was the last time your sales department participated in a management review? When was the last time your sales department used the corrective and preventive action system? When was the last time your sales people had a formal review or had a defined training plan? When was the last time sales was involved in quality? If the answer is never, then how in the world do you want ISO 9001 and quality to help your sales? It only starts when you allow this to happen.
Of course the case presented here may work for some organizations and not for others and may apply more to some organizations and not for all. But I hope that it gives you a good idea that even your outside sales gurus could benefit from some basic process mapping, documenting and objective setting. After all, your organization has the right to expect every one and every process apply the same world-class quality principles your company deserves.
If ISO 9001 is good for your processes, then make sales become part of it.
Miriam Boudreaux is the President of Mireaux Management Solutions, a consulting firm headquartered in Houston, TX. Mireaux’s products and services encompass ISO consulting, ISO Training, Internal Auditing, implementation of the Web-Based QMS platform and electronic QMS hosting.
Miriam holds a B.S. and a M.S. in Industrial Engineering. She is a certified QMS and certified ISMS Auditor as well as a Certified Quality Engineer(CQE) and a Certified Quality Manager. Miriam has served as an Examiner with the Texas Award for Performance Excellence and has also been a speaker at International Conferences.
Before venturing on her own, Miriam held executive positions in Quality and Engineering. She successfully led her companies through ISO 9001, ISO 14001, QS 9000 and TL 9000 certifications. Besides her current position as President and head consultant of Mireaux, Miriam also provides her auditing services to a major international ISO registrar.
To get in touch with Miriam Boudreaux please contact her at miriam@mireauxms.com.
Conforming to the Intent
I enjoyed reading everyone's comments. So much can always be said about so many organizations. I recognize that part of my example could very well be interpreted as inside sales for a company. However true outside sales -the processes that happen before a customer order is received- are usually left out of the loop. I have seen greatness using the ISO 9001 standard, therefore I believe every process in the organization can benefit from it. Regardless of the quality of their audits, a company who is matured and committed to their quality management system and applies the concepts as intended, is set to gain significant value, specially if they apply that to all their processes. Thanks all!
Mmmm, what do these registrars think they're playing at?
Hi Miriam,
Good article but I'm amazed by the implication.
Forgive me for pointing this out, but ISO 9001 is and always has been a purchasing standard; it was developed in the 1960s by NATO AC 250 for that very purpose. So the sales process is and always has been right at its core. In the good old days before TC 176 defocused its gaze by trying to make ISO 9001 more than it ever could be, clause 4.3 placed a very clear specification on ensuring that the sales pitch was right. Those of us who learned our craft in the 1980s in the maelstrom of the UK National Quality Campaign learned very quickly that the antithesis of an effective quality system was the sales jockey who said, "the answer's yes, what's the question?" And we raised issues when it became evident that quality systems didn't take heed. Indeed I still raise issues these days against the requirements in ISO 9001/7.2 if there is even the slightest evidence that the organization is committing to supply when it is unable to show me it has both the capability and capacity to deliver in full, on time, in specification (DIFOTIS) and on budget. As I say, that consideration is the very genesis of ISO 9001 and its predecessors.. And woe betide any organization claiming to meet ISO 9001. 4.1 a), b) and c) if the sales process isn't clearly identified, properly sequenced and interrelated to resource management, purchasing and design control to name just three. It's the reputational and commercial viability risks that are predominant here, both of them clearly within the scope of the quality policy and objectives that can reasonably be expected to come up against clauses 5.3 and 5,4..
The implication in your article is that registrars are no longer concerning themselves with this most fundamental of conformity points. The fact has always been that ISO 9001 is the minimum for ensuring that sales orders are delivered, so leaving out the sales process in an implementation audit is negligent; simple as that.
Once again I'm forced to conclude that quality system certification is not safe in the hands of the current crop of registrars or the accreditation agencies that purport to validate them. More effective auditing, less pecking away at poorly configured laptops, that's what we need from registrars....
Maybe it's time for us professionals to come up with a better alternative. Maybe we should start by doubling the time allowed and doubling the fees. Then only the clients who understand the benefits will remain, because the dullards won't be bothered. At that point ISO 9001 will mean something once more.
All the very best.
Ian
Registrars
Ian,
Good points all; do Brits take ISO 9001 compliance seriously? IMHO, registration's a joke here in the colonies. Companies want the certificate and the heck with operational excellence. But I wouldn't try to fix the system, I would eliminate it. The standard is fine - but only 2 parties can assess a supplier's performance: the supplier and the customer. Registrar auditors can't be expected to assess the dynamic issues that drive success - issues which sometimes can't be shoehorned into a checklist. The entire registration system should be scrapped without replacement.
> Besides, ISO 9001 puts a burden on a supplier but puts no burden on its customers. Many companies succeed despite their customers, not because of them. Industry would be better served if ISO 9001 was a guide on how the customer-supplier interface were properly managed, with neither side being given an advantage.
Great article, Miriam. May I add a Dilbertism? Salespeople should be aware of what their company is capable of, and ideally be able to answer prospects' questions in real time, or at least have a pipeline to the people who can supply the correct answer.
Unrelated to the above: I once "spec"ed 3 optical comparators - the most expensive was nearly twice the price of the least expensive with no major variation in functionality among the 3. I asked the rep for the expensive brand why I should purchase his, and was prepared to make the case to my management if his answer made sense, but all he could say was essentially "Our comparators are best because we say they are". I didn't buy his product. The lesson here is for Sales and Product Design to align to determine what constitutes value.
Can you suggest further reading on your topic?
More on registration/certification/accreditation
Hi Dave,
Unfortunately, I think I agree with you.
I don't know what happens in the UK these days, I'm a migrant downunder. In this part of the world, certifiers pay peanuts for auditors and allow ridiculously little amounts of time on certification auditing. And the accreditation system misses it.
I also know that for the first 15 years at least, nearly all the world's certificates were issued to ISO 9002 (ie ISO 9001 without the design/development requirements) when ISO 9001 was always the default in the commercial sector (after all, the only thing you really want to know about any supplier is their products and services have been designed to meet your needs and continually upgraded accordingly and under control). And the accreditation system missed it. So it’s never been good, in my view.
As for your point about only the supplier and the customer being relevant, I sympathise with that one too. I remember that the whole idea back in early 1980s was to set up a system whereby multiple audits were replaced by accredited certification on the basis of properly trained and credible auditors and auditing processes. This got lost, of course, in the battle for margins and certification market share. And the accreditation system missed this one too.
Also, if you view the ISO Survey, you’ll see over successive years that the mature markets with the highest certifications per capita, such as the UK, Australia and New Zealand are in decline, so maybe it’s coming home to roost.
The current supply of registration/certification has had its day, not because of the standard itself, but because the whole business and its parasitic accreditation system has allowed it to become that way.
I am a real fan of ISO 9001, have been since I did my Lead Assessor course in 1984. What’s missing now is the underpinning of the variety that supports type testing in product certification. I think we need TC 176 to come up with the minimum requirements that have to met to demonstrate conformity with ISO 9001's 224 individual requirements. Then claims to comply will become transparent.
So, my message to TC 176 is this. Stop gilding the lily. Start a brave new world. Work on the type tests that show implementation is effective. The time has come for you to protect your patch; get into damage control mode. Over the last 25 years the world’s certifier/registrars and the accreditation systems that live off them have let you down.
Cheers
Ian
Sales Process Engineering reference
Hi Dave and Miriam,
I just came across this.... http://en.wikipedia.org/wiki/Sales_process_engineering .....very interesting.
Cheers
Ian
Sales Reps and Quality
Thank you for reading the article Dave. Your example is indeed a good testimony of process lacking. I do have a good book to recommend. Please send me your email directly at miriam@mireauxms.com.
  • Classifieds
  • File Share
  • Forum Topic
  • Events
  • Links
Sign In to get started!
Quality Information
