(ATS: Norwood, MA) -- Advanced Thermal Solutions Inc. (ATS), an engineering/manufacturing company focused on the thermal management of electronics, now provides a flexible, robust candlestick sensor, the MS 1000-CS-WC, that can simultaneously measure both temperature and air velocity for characterizing thermal conditions in electronic systems.
The MS 1000-CS-WC sensor is narrow with a low profile to minimize disturbance of heat flow in the test domain. Its flexible, plastic-sleeved stem eases installation and repositioning during the testing process. It has a plastic base to eliminate any potential shorting issues.
Multiple sensors are easily installed to thoroughly map a system’s thermal and airflow conditions. The use of a single sensor to measure both temperature and velocity eliminates errors that can occur when airflow is non-isothermal.
