FlackTek Launches MEGA FlackTek
High-speed bladeless planetary mixer
Thu, 10/16/2025 - 12:02
(FlackTek: Landrum, SC) -- FlackTek, a pioneer in high-performance materials processing, has launched the MEGA FlackTek—the world’s most sophisticated and largest high-speed bladeless planetary mixer. It’s now available for commercial orders.
With an hourly output measured in tons per hour, the MEGA empowers manufacturers to scale breakthrough formulations from R&D to full-scale production without compromise. This technology replaces traditional industrial bladed mixers and revolutionizes the typical manufacturing process.
Engineered to transform not just how materials are processed but how production environments are designed, the MEGA FlackTek redefines what’s possible in precision mixing, facility layout, and manufacturing throughput. Its clean, bladeless system eliminates cleanup and cross-contamination concerns. Advanced control features support modern production flows ranging from small-batch pilot runs to continuous, high-volume output.
“This isn’t just about scale. It’s about freeing our customers from legacy constraints and giving them the flexibility to rethink their entire process, from formulation to floor plan,” says Matt Gross, FlackTek CEO. “The MEGA FlackTek helps teams accelerate development, reduce downtime, and deliver the same repeatable results from grams to tons.”
Built for modern manufacturing
The MEGA platform extends FlackTek’s trusted technology, known for precision materials processing from mixing to dispersion, emulsification to deagglomeration, degassing, and more, into high-throughput environments. It’s compatible with both reusable and single-use containers and supports full vacuum and inert gas conditions for sensitive or reactive materials. Optional features such as full remote operation, temperature monitoring, video monitoring, and automated data logging enhance traceability and process control.
Proven efficiency gains at scale
In industrial deployments of FlackTek’s technology, customers across advanced manufacturing—including major sectors like batteries, aerospace, food processing, and specialty chemicals—have reported dramatic gains in throughput, safety, and consistency. One partner replaced a multistep, labor-intensive production process with the MEGA FlackTek and achieved 24-times faster output while eliminating cleanup and using automation to reduce material handling.
A platform that scales with you
Whether you’re validating a formulation in a benchtop beaker or producing tons of material in a production day, FlackTek offers a unified ecosystem to support every stage of your process. This seamless scale-up enables teams to maintain process fidelity, reduce time to market, and streamline regulatory workflows while simplifying facility complexity.
Key capabilities:
• Production capacity up to 1,200 kilos per hour
• Environmental control: full vacuum and inert gas purge capable
• Automation-ready: supports robotic integration and smart electronics
• Optional features: temperature control, video monitoring, data logging
• Flexible containment: compatible with reusable or single-use drums
FlackTek’s application lab and facility in Boulder, Colorado, is available to host demos, scale-ups, and process optimization for all products, including MEGA. To experience the difference and explore how you can scale from beaker to bulk, watch this video or visit https://www.flacktek.com/MEGA.
About text formats
