A Primary Standard for Measuring Vacuum
Tracking changes in fluorescence from ultracold atoms is a super-sensitive indicator of pressure
NIST
Thu, 08/18/2022 - 12:02
A novel, quantum-based vacuum gauge system invented by researchers at the National Institute of Standards and Technology (NIST) has passed its first test to be a true primary standard—that is, intrinsically accurate without the need for calibration.
Precision pressure measurement is of urgent interest to semiconductor fabricators that make their chips layer by layer in vacuum chambers operating at or below one hundred-billionth the pressure of air at sea level. They must rigorously control that environment to ensure product quality.
NIST scientist Stephen Eckel behind a pCAVS unit (silver-colored cube left of center) that is connected to a vacuum chamber (cylinder at right). Credit: C. Suplee/NIST
“The next generations of semiconductor manufacturing, quantum technologies, and particle acceleration-type experiments will all require exquisite vacuum and the ability to measure it accurately,” says NIST senior project scientist Stephen Eckel.
