Usage:
This not-contact vision measuring system comprises of high resolution and accuracy CCD, continuous zoom lens, high precision linear scale and stage. It is a photoelectric measuring system with high precision and efficiency which is widely used in various precision industries.
Application: suitable for electronic, molding, press, spring, screw, tool, plastic, rubber, valve, camera, bicycle, motor parts, PCB, conduction rubber, interference board, lead frame and other precision industries
Features:
• Solid granite frame guarantees strength, accuracy and stability
• Precision stages are available
• Higher resolution linear encoder 0.5µm
• Superb full-color high resolution image with zoom optics
• Sighting device: cross-hair generator
• Connection: RS232 or USB output and metrology software
• High resolution S-video color CCD camera
• New MC 800 geometric DRO
• One-click edge detection
Specifications:
Model No
EV-1510
EV-2010
EV-2515
EV-3020
EV-4030
Travel-X.Y axis
150*100(mm)
200*100(mm)
250*150(mm)
300*200(mm)
400*300(mm)
Travel-Z axis
150
150
150
150
150
Stage size
354*228
404*228
450*280
500*330
606*466
Stage load capacity
30kg
35kg
40kg
Dimension L*W*H
540*560*850
540*560*850
760x600x900
760x600x900
970x670x940
Net weight
98kg
108
120
138
238
