Contact: Abby Liao
Email: topoilpurifier@gmail.com
T/F: +86-23-88901306
Skype ID: topoilpurifier
Yahoo messenger ID: topoilpurifier@yahoo.com
MSN/Live/Hotmail ID: topoilpurifier@hotmail.com
Gtalk ID: topoilpurifier@gmail.com
Series TYA is widely used in metallurgy, machinery, oil field, chemistry, mine, electric power generation plant, transportation and manufacturing enterprises for hydraulic oil, gear oil, engine oil, compression oil, freezer oil, heat treatment oil, compressor oil, refrigeration oil and other industrial oils. It can remove water, gas and eliminate mechanical impurities, light acid and light hydrocarbon from oil, and improve oil quality, resume its lubricating property and ensure normal operation of the equipment.
Characteristics:
1. Super ability in breaking emulsion, dehydration and degassing process. Adopting big-cubage, reinforced three-dimension flash distillation column, thin film evaporation technique and large area multi-level separation technique so as to remove water, gas and light hydrocarbon material efficiently and quickly.
2. Adopting high-quality filter element and sealing material with corrosion proof, high temperature resistance and excellent mechanical strength, it is suitable even for purification process of high-viscosity oil under rather high temperature conditions and in this way expanding its application scope.
3. Fine and precision multi-stage filtration system can remove mechanical particulates thoroughly and effectively.
4. With air-cooling and condensation system, it can cool the air in the vacuum system efficiently and quickly, which avoids inconvenience of water-cooling.
5. Advanced high pressure protection device and infrared oil level control system for easy operation.
6. Perfect automatic and manual oil heating temperature controller, automatic cooling and separation device, simple, safe and reliable.
7. Aluminum electrical control cabinet, with high efficiency for heat transfer and anti-explosion.
8. The equipment can also be installed with digital flow meter and timer for auto calculating and recording oil volume and working time. (it’s optional according to user’s requirement)
Product line:1: Transformer Oil Treatment System2: Lubricating Oil Purification Unit3: Turbine Oil Conditioning System4: Hydraulic Fluids Filtration Machine5 Light Oil (Fuel) Filtering Unit
6: Engine Oil Regeneration Plant7. Vegetable Oil Purifier8. Heat Transfer Oil Purifier9. Centrifugal Oil Filtration Unit
10. Plate pressure oil purifier
11. Portable oil filtering and oiling machine
12. Vacuum dehydrator
13. Explosion protection filtration machine14.. Oil Analyzer
