Series TYA oil purifier is applied to recover and purify various high-precision lubricating oil such as hydraulic oil, mechanical oil, coolant oil, gear oil, heat treatment oil and so on.Features1. Strong capability of breaking emulsification.2. The combination of coalescing separation and vacuum dewatering.3. More Deeply and precisely FH rectangular filtering system. 4. Zhongneng’s unique technology with H.P.M high polymeric adsorbing material. AdvantagesThis machine can fast degas, dewater, and remove the impurity and the volatile matter (for example ethyl alcohol, gasoline, ammonia and so on). Enhances the oil quality, restores the lubricating oil viscosity, flash point and improves the oil capability. Guaranteed the hydraulic system, dynamic system and lubricating system running normally.Our Main Products: Series ZY Single-Stage Vacuum Transformer Oil Purifier Series ZYD Double High Vacuum Transformer Oil Purifier Series ZYB Multiply-Function insulating oil treatment machine Series TY Turbine Oil Purification Apparatus Series TYA Lubricating oil/ hydraulic oil purification unit Series LYE Engine oil recycling system Series TYB Portable light Fuel oil purification machine Series PL Plate pressure oil purifier Series TYD Vacuum dehydrator Series EFD Explosion protection filtration machine Series JL Portable oil filtering and oiling machine Series IIJ Oil Tester (BDV Tester) .E-mail: chinaoilpurifier@gmail.com chinaolipurifier@hotmail.com
Terms of Use
I agree to the terms of use:
