3D Scanning With Two 16-Megapixel Cameras
Breuckmann
Wed, 02/19/2014 - 14:13
(Breuckmann: Meersburg, Germany) -- The range of scanning products offered by Breuckmann now includes the precise stereoSCAN-R16. Three-dimensional metrology at the highest level can be accomplished using this two-camera system, which is usable in almost any situation, thanks to its excellent mechanical and thermal stability. Whenever it comes to measuring the finest structures or minutest deviations, the stereoSCAN is the system of choice.
The stereoSCAN-R16 is now equipped with two 16 megapixel cameras, which means that the measurement data are calculated on the basis of 32 megapixels. The system is characterized by extremely high-resolution detail and measuring accuracy, which to date has only been achievable using coordinate measuring systems. This system configuration is predominantly used in large-scale measuring fields, where the operator is able to choose either the highest camera resolution or the fastest data acquisition, thus ensuring that each 3D scanning project is processed using the optimal system configuration. The resulting large data volumes are processed using OPTOCAT measuring and evaluation software, which can be used in diverse analysis tasks.
3 Things You Should Never Say When Presenting
