  HomeSearchSubscribeGuestbookAdvertise June 21, 2026
Resources
Back Issues
Zeiss CONTURA Coordinate Measuring Machine
Peak Process Consulting
CMM Helps Small Business Sustain Large Profits
In an increasingly competitive business environment, it’s often necessary to take risks with capital expenditures in order to stay ahead of the curve. However, anticipating future customer needs can be a tricky endeavor, and businesses are best served by extensive research and analysis before taking the leap and investing in training, equipment or software.
When Evden Enterprises, a custom component manufacturer located in Ukiah, California, entered the market for a new coordinate measuring machine, it knew that the CMM would be an integral element of the company’s production line. Evden also knew that purchasing a new CMM was the next logical step in expanding its capabilities--and that staying ahead of the competition while generating new business required the right equipment and the best technology available.
Evden Enterprises’ history has been a profile of metered expansion and prudent business decisions. Since its inception in 1980, the company has grown from four employees to 24. The company’s customer base grew as well and now comprises primarily Fortune 500 companies in the mineral, mining and oil-drilling industries. Using detailed customer specifications, Evden transforms a variety of materials--including stainless steel, aluminum, brass and plastic--into precision parts used in applications as diverse as drilling equipment sampling systems and ophthalmology instruments.
Evden already owned an ECLIPSE CMM with an ST touch-trigger probe from Carl Zeiss IMT Corp. “In past years, increasingly tighter tolerance requirements and more complex parts have become standard,” says Stephen McGrath, vice president of manufacturing at Evden. “We needed to measure parts with extremely small hole sizes and realized that in order to satisfy our customers’ needs, we had to move to the next level.” In 2002, McGrath decided to replace his company’s ECLIPSE with a Zeiss CONTURA active scanning CMM using a VASTXT probe head.
“The scanning capability of the CONTURA and the programming flexibility of the CALYPSO software allow us to inspect multi-faceted parts,” explains McGrath. “With the VASTXT, we can now perform required roundness checks and inspect features smaller than 2 mm in diameter. We’re also able to measure complete parts. Before, we were only able to measure key features; the rest would have to be checked in a cumbersome manual process.”
Evden performs in-process inspections and uses the CONTURA to check individual operations. Instead of assessing product quality at the end of the line, this method decreases scrap and rework by maintaining accuracy throughout the fabrication process. “There is no final inspection before the part goes out the door,” notes McGrath. “We rely on all of the different operations and steps to be accurate on the spot.” McGrath wanted to meet targeted true-position tolerances to 0.05 mm (0.002 in.). “With the scanning VASTXT probe head collecting thousands of data points in just a few minutes, we’re able to achieve accurate and reliable results on extremely intricate parts.”
The CALYSPO CAD-based software reduces programming time by 50 percent, allowing operators to perform complex measurements expeditiously. The training program was equally fast; McGrath attended the class and then trained some of his lead employees who, in turn, trained other operators--saving Evden and its employees travel costs and valuable time away from work. “The software is pretty intuitive,” says McGrath. “With CALYPSO, you don’t need an operator with a Ph.D. in geometry. It’s the most user-friendly software we’ve used.”
Amid a volatile business climate rife with economic obstacles, Evden has been able to maintain its output and remain profitable. This stands in contrast to other manufacturers that have experienced decreases in production in recent years.
“Customers are interested in how you’re keeping up with technology and if you’re improving your processes,” says McGrath. “We have several larger companies that are registered to ISO standards and review us annually, and that’s important to them. Purchasing the CONTURA has opened the door to more orders. This shows that continuous improvement of processes and capabilities can lead to new business and increase profitability.”
Benefits
  • Active-scanning sensor for high-speed data acquisition of multifaceted parts
  • User-friendly CAD-based software reduces programming time by 50 percent.
  • Ceramic guideway technology provides high stability against temperature changes and dynamic influences.
www.zeiss.com
