(Delcam International Inc.: Windsor, Ontario, Canada) -- Delcam previewed the forthcoming version of its PowerINSPECT inspection software at the Control exhibition held in Stuttgart, Germany, May 5–8. This new release of the world’s leading hardware-independent inspection software is scheduled for release in the summer and will include a range of enhancements to make it easier and more flexible to use.
The most obvious change will be a completely new interface for undertaking “simple” measurements. This will make it much easier to undertake basic tasks, such as measuring the distance between two points or two planes, or the centers of two circles, or checking the thickness of a section.
It has also been made easier to add or delete points during an inspection from a set of measurements defining any feature. Points might need to be added to collect extra data from a suspect area, while “rogue” measurements can be deleted to prevent them from affecting the overall inspection.
A number of improvements have been made to the ways in which data within geometric features can be handled. The attributes of each point making up the sequence will be able to be displayed separately, either as the renowned PowerINSPECT dots or as needles proportionate in length to the extent of the deviation. This will make it easier to see where the problems areas are, especially in bigger parts with large numbers of measurements.
