(SignalFire: Marlborough, MA) -- SignalFire Wireless Telemetry, a leading manufacturer of industrial wireless telemetry products, is partnering with Axess-Corrosion, a United Kingdom provider of corrosion monitoring sensors, to integrate SignalFire’s RANGER cellular transmitter in a new pipeline corrosion monitoring solution.
Monitoring pipeline corrosion is important to determine the ongoing degradation of pipes and prevent leaks, process challenges, and failures. The new pipeline corrosion monitoring solution from Axess-Corrosion combines the RANGER IoT transmitter with a sacrificial sensing probe to provide data and alarms on pipeline corrosion levels.
In operation, the probe, which is inserted into the pipe, is equipped with a depleting “sacrificial” membrane and can detect corrosion or erosion of the membrane as finite as 0.0001 in. By measuring depletion rate, the probe provides feedback on the predicted rate of corrosion on the pipeline wall. It is critically important to oil producers to receive feedback about the performance of expensive, corrosion-inhibiting chemicals and whether the dosage rate is optimal.
