Product News: IQS Announces New Problem Solving Capabilities
Streamline and strengthen the problem solving process by promoting collaboration.
Thu, 01/07/2010 - 07:46
(IQS: North Olmsted, OH) -- IQS announces the availability of IQS Problem Solver module that enables organizations to standardize problem solving processes with easy-to-use questioned-based reasoning software. Failure to standardize problem solving, capture reasoning, and effectively use your technical experts costs money (much more than you probably realize). You do not need to accept this as a normal cost of doing business.
The IQS Problem Solver module is designed to streamline and strengthen the problem solving process by promoting collaboration between groups of employees and suppliers striving to find true root causes and putting permanent countermeasures into place.
The module supports the eight disciplines (8D) process of problem solving, the A3 process (which is rooted in the plan-do-check-act methodology), 5 Whys (used for root cause analysis), and lean methods.
The module facilitates problem solving with the following features and benefits:
