![](/sites/default/files/editorial_images/API640_1.jpg)
Siemens-Mobility’s factory in Graz, Austria, is a development center and manufacturing plant for high-tech bogies, an important component of the global rail vehicle industry. Whether bogies for streetcars, locomotives, passenger coaches, or high-speed multiple units, the Siemens Mobility World Center of Excellence for Bogie Technology covers the complete product range for track-bound traffic.
The high productivity stands for a degree of automation that is unique worldwide. Using technology in mechanical production in particular sets new standards; for setup and clamping, the chassis frames have already been successfully measured for many years using API measuring solutions. Since 2022, they have been measured using the latest generation of the Radian Laser Tracker and the vProbe wireless 3D sensor, delivering:
• Recess measurement up to 30 mm with extended stylus
• Mounted tracker measurements for stability and availability
• Automated workflow to support shift operations
