Failure of a machine in a factory can shut it down. Lost production can cost millions of dollars per day. Component failures can devastate factories, power plants, and battlefield equipment.
To return to operation, skilled technicians use all the tools in their kit—machining, bending, welding, and surface treating, to make just the right part as quickly and accurately as possible. But there’s a declining number of technicians with the right skills, and the quality of things made by hand is subject to the skills and mood of the artisan on the day the part is made.
Both problems could soon be solved by artificially intelligent robotic technicians. These systems can take measurements; shape, cut or weld parts using varied tools; pass parts to specialized equipment; and even purchase needed materials—all without human intervention. Known as hybrid autonomous manufacturing, this process involves automated systems that seamlessly use multiple tools and techniques to build high-quality components where and when they are needed.
