Photo by Ruozhu Feng, Pacific Northwest National Laboratory
A new mini flow cell battery (right) is designed to speed the testing of promising new flow battery technologies.
Sometimes, to go big you first have to go small. That’s what researchers at the U.S. Department of Energy’s Pacific Northwest National Laboratory have done with their latest innovation in energy storage.
With a goal of speeding up the time to discovery of new grid energy storage technology, the team designed a compact, high-efficiency flow battery test system that requires an order of magnitude less starting material while delivering results equal to the standard lab-scale test systems. The new mini flow cell design and experimental validation are described in an article published in the Journal of The Electrochemical Society. The redesigned mini flow cell closely mimics the internal structure of a traditional flow cell, scaled down by a factor of five. Despite its smaller size, the mini flow cell exhibits performance comparable to its larger counterpart.
Mini flow battery delivers big results
“This report is the first step, showing that scaling down our experimental system works,” says materials scientist and flow battery researcher Ruozhu Feng, a lead author of the study. “Our ultimate goal is to bring the power of AI and robotics into this process to automate and accelerate the testing of new flow battery designs.”
By reducing the amount of material needed and speeding up the validation process, this technology could help advance renewable energy solutions. Researchers also believe this miniaturized approach will facilitate experimentation with a broader range of experimental chemistries.
“Currently, we have to prepare a lot of material when we identify a promising new battery formula, and this takes a lot of time,” Feng says. “With this mini flow cell process, we can figure out whether a proposed new material works with only a tiny amount—milligrams—available.”
The mini flow cell design is geared toward research laboratories that are focused on rapid screening and development of new battery materials. In its research study, the team showed that the new mini flow cell is suitable for rapid validation of material stability. Rigorous testing over a wide range of material chemistries and concentrations helped boost researchers’ confidence in the new scaled-down system. However, the team does note that it requires highly purified starting materials that are free from material that could otherwise clog the narrow channels and tubes.
The research team has applied for U.S. patent protection for its new battery design. To learn more about collaboration or licensing opportunities related to the new technology, contact the PNNL’s commercialization team.
A team effort
According to the lead researcher and designer of the mini flow cell, Soowhan Kim, a big key to their success was that the team has more than a decade of experience in flow battery cell design, along with engineering, skilled machining, and chemistry experience. For example, PNNL instrumentation and systems control expert Andrey Liyu used his mechanical engineering and microfluidics experience to complete the scale-down without sacrificing accuracy.
“From small cells to big stacks, we can handle all scales of flow battery design and experimentation,” said Kim, a lead researcher at PNNL’s Grid Storage Launchpad. “When we add the computational expertise and analytical chemistry experience, this is how we combined efforts to develop the mini flow cell. Our hope is to make this available to all researchers who are interested in using it.”
What is a flow battery?
As their name suggests, flow batteries consist of two chambers, each filled with a different liquid. The batteries charge through an electrochemical reaction and store energy in chemical bonds. When connected to an external circuit, they release that energy, which can power electrical devices. Flow batteries are a linchpin technology. They store energy from intermittent energy sources such as wind and hydroelectric power, and then release that energy on demand for grid-scale applications. Unlike traditional batteries, flow batteries use liquid electrolytes stored in external tanks, providing flexible scaling of energy capacity.
In this example of a commercial-scale flow battery, an aqueous iron (Fe) redox flow battery captures energy in the form of electrons (e-) and stores it by changing the charge of iron in the flowing liquid electrolyte. When the stored energy is needed, the iron can release the charge to supply energy (electrons) to the electric grid. Animation by Sara Levine, Pacific Northwest National Laboratory.
To make flow battery systems practical for large-scale use, researchers are seeking new chemical and material combinations that address limitations of existing systems. Some of these limitations include high material costs, low power density, and the desire to source materials domestically in the United States.
Commercial grid-scale battery energy storage systems, illustrated above, are 1,000 to 2,000 times the size of the experimental mini flow cell. Animation by Cortland Johnson, Pacific Northwest National Laboratory.
How are new flow batteries discovered?
Traditionally, the discovery of new materials for flow batteries has been a laborious trial-and-error process often requiring gram-scale synthesis of organic compounds, extensive testing, and significant time investment. This new miniaturized cell design, about the size of a playing card, uses the equivalent of a few grains of sand, drastically reducing the time and resources required for each test while still delivering reliable results.
In addition to Feng, Liyu, and Kim, the research team included PNNL scientists Chao Zeng, Carter C. Bracken, Yangang Liang, and principal investigator Wei Wang. This research was supported by the Energy Storage Research Alliance (ESRA), an Energy Innovation Hub funded by the U.S. Department of Energy, Office of Science, Basic Energy Sciences program, and the Energy Storage Materials Initiative, a PNNL-directed strategic research investment.
The ESRA unites leading experts from national laboratories and universities to pave the way for energy storage and next-generation battery discovery that will shape the future of power. Learn more at Energy Storage Research Alliance.
Published Feb. 13, 2025, by Pacific Northwest National Laboratory.
