![](/sites/default/files/editorial_images/lean-tech640.jpg)
When most people think of lean processes, they believe the goal is to optimize things in a step-by-step approach. The result that companies using lean methods can look forward to is incremental improvements brought about by the elimination of waste.
Individuals who stick with this definition often assert that lean principles oppose innovation. That’s because “innovation” is typically considered a product-based form of invention that causes disruption. Lean manufacturing is all about following well-defined processes and figuring out how to make them better. Innovation, on the other hand, usually occurs by uprooting current processes or blatantly not following them.
It may appear that lean manufacturing and innovation are opposed. However, some analysts assert that when companies recognize the compatibility between lean principles and innovation they will accelerate past their competition.
