(Vici & C. S.p.A.: Santarcangelo di Romagna, Italy) -- Arcoprofil, a machine shop in Schio, Italy, has found a dependable, efficient, and effective solution in the VICIVISION measuring machine.
The ease in the process of measuring with a VICIVISION not only streamlines production but also enables operators to be confident about the parts they produce. Arcoprofil pairs automation with its VICIVISION machine, allowing mostly hands-free operation.
Operators previously measured manually, a time-consuming task. But now VICIVISION requires almost no involvement from the operator. One of these operators says, “I think the advantage of having a VICIVISION measuring machine is that I can proceed with an entire batch once the measurement is complete. The results are quick and reliable, where obtaining measurements before was time-consuming and unreliable.”
Parts rejected by the VICIVISION machine reenter the production cycle as much as possible to reduce waste.
Arcoprofil measures turned parts and shafts with the VICIVISION optical measuring machine’s metrology quality-control process.
