(AW-Lake: Oak Creek, WI) -- AW-Lake, flow instrumentation manufacturer, has launched the TN Turbine flow meter. This meter offers a cost-effective solution for measuring light viscosity fluids, including glycol, water, and solvents. It can be used for liquid flow measurement both on or off the oilfield. Additionally, the TN Turbine flow meter serves as an easy drop-in replacement for other brands of flow meters.
With flow ranges from as low as 0.3 gallons per minute (GPM) to as high as 5,500 GPM, the TN Turbine flow meter is accurate to within ±1% of reading and offers repeatability of ±0.1% across the full range. Available in a wide range of sizes, the turbine flow meter provides multiple process connections and can work with various existing electronics. Its all-stainless-steel construction and precise machining tolerances ensure excellent durability and long life, making it suitable for even the most demanding flow measurement applications.
The TN Turbine flow meter can be employed in various industries, including oil pipelines, water applications, and test systems in aerospace and automotive plants. It’s also used in HVAC and building automation, beverage processing, and power generation. The turbine flow meter performs best under steady flow conditions because turbulence, fluctuating flow, or cavitation can affect performance and accuracy.
For more information, contact Marcia Reiff, director of marketing communications, (414) 574–4300, email mreiff@aw-lake.com, or visit AW-Lake’s website.
