(EMUGE-FRANKEN USA: West Boylston, MA) -- EMUGE-FRANKEN USA, a leading manufacturer of high-performance taps, thread mills, end mills, drills, gauges, and other rotary tools, has expanded its precision thread gauges line with tin-coated gauges featuring 3B class-of-fit, ensuring that critical tolerance is met. The tin coating also ensures extreme wear resistance for safety-critical aerospace and medical applications as well as other demanding environments.
EMUGE tin-coated thread gauges have high dimensionally stable HSS construction with tin coating that increases hardness and wear resistance. This extends gauges’ lifespan and reduces the frequency of calibrations and replacements, saving time and cost. By minimizing friction, EMUGE tin-coated gauges offer consistent measurements and precision thread sizing. The tin coating also provides a protective barrier against abrasion and corrosion, even with hard or abrasive materials and harsh environments. EMUGE tin-coated gauges are available with a 3B class-of-fit in sizes No. 4 through 1 in. UNC/UNF as well as metric sizes.
“We are pleased to expand our line of precision thread gauges with durable tin-coated gauges, which offer improved accuracy when gauging a range of threading applications, such as challenging, precise aerospace and medical threaded holes,” says Robert Adamiak, sales support specialist at EMUGE-FRANKEN USA.
EMUGE-FRANKEN’s comprehensive line of thread gauges consists of go/no-go plug gauges, thread-depth plug gauges, and ring gauges. A certificate of accuracy is furnished with each gauge. For more information on the new tin-coated gages, click here. For more information on the full line of EMUGE precision thread gauge solutions, click here or download a full line brochure.
