(Fastec: San Diego, CA) -- Fastec Imaging’s IL5 high-speed 5MP camera enables you to record production lines moving at high speed for performance or quality analysis, or troubleshoot using slow-motion replay, so you can see what you’ve been missing with normal speed video.
With four models to choose from, boasting crisp, clean video, from 2560 x 2080 at 230 fps to 800 x 600 at 1,650 fps, there is an IL5 to fit your application needs. All models record more than 3,200 fps at VGA resolution, and more than 18,000 fps at smaller resolutions. Able to save images to an SSD or SD card while recording high-speed bursts of hundreds or even thousands of images at a time, the IL5 is always ready for the next high-speed snapshot. With a base model starting below $9,000, the IL5 is a cost-effective solution to record high-speed events for slow-motion analysis.
