(NIST: Gaithersburg, MD) -- Andrew Iams saw something strange while looking through his electron microscope. He was examining a sliver of a new aluminum alloy at the atomic scale, searching for the key to its strength, when he noticed that the atoms were arranged in an extremely unusual pattern. “That’s when I started to get excited,” says Iams, a materials research engineer, “because I thought I might be looking at a quasicrystal.”
Not only did he find quasicrystals in this aluminum alloy, but he and his colleagues at the National Institute of Standards and Technology (NIST) found that these quasicrystals also make it stronger. They published their findings in the Journal of Alloys and Compounds.
The alloy formed under the extreme conditions of metal 3D printing, a new way to make metal parts. Understanding this aluminum on the atomic scale will enable a whole new category of 3D-printed parts for items such as airplane components, heat exchangers, and car chassis. It will also open the door to research on new aluminum alloys that use quasicrystals for strength.
What are quasicrystals?
Quasicrystals are like ordinary crystals, but with a few key differences.
A traditional crystal is any solid made of atoms or molecules in repeating patterns. Table salt is a common crystal, for example. Salt’s atoms connect to make cubes, and those microscopic cubes connect to form bigger cubes that are large enough to see with the naked eye.
This Penrose tile pattern has some of the same properties as quasicrystals. Even though the image is made of a few identical basic shapes, the overall pattern never repeats. Credit: elfinadesign/Shutterstock
There are only 230 possible ways for atoms to form repeating crystal patterns. Quasicrystals don’t fit into any of them. Their unique shape lets them form a pattern that fills the space but never repeats.
Dan Shechtman, a materials scientist at Technion-Israel Institute of Technology, discovered quasicrystals while on sabbatical at NIST during the 1980s. Many scientists at the time thought his research was flawed because the new crystal shapes he found weren’t possible under the normal rules for crystals. But through careful research, Shechtman proved beyond a doubt that this new type of crystal existed, revolutionizing the science of crystallography and winning the chemistry Nobel Prize in 2011.
Working in the same building as Shechtman decades later, Iams found his own quasicrystals in 3D-printed aluminum.
How does metal 3D printing work?
There are a few different ways to 3D-print metals, but the most common is called “powder bed fusion.” Metal powder is spread evenly in a thin layer. Then a powerful laser moves over the powder, melting it together. After the first layer is finished, a new layer of powder is spread on top, and the process repeats. One layer at a time, the laser melts the powder into a solid shape.
NIST’s 3D printer testbed: This 3D printer builds objects by melting a fine metal powder with a laser. First, the surface is coated with metal powder. Then, a high-power laser melts that powder in a particular pattern. The process is repeated hundreds or thousands of times, building the metal piece layer by layer. Finally, when the object is complete, the excess powder is removed. Credit: Jennifer Lauren Lee/NIST
3D printing creates shapes that would be impossible with any other method. For example, in 2015 GE designed fuel nozzles for airplane engines that could only be made with metal 3D printing. The new nozzle was a huge improvement. Its complex shape came out of the printer as a single lightweight part. In contrast, the previous version had to be assembled from 20 separate pieces and was 25% heavier. To date, GE has printed tens of thousands of these fuel nozzles, showing that metal 3D printing can be commercially successful.
One of the limitations of metal 3D printing is that it only works with a handful of metals. “High-strength aluminum alloys are almost impossible to print,” says NIST physicist Fan Zhang, a co-author on the paper. “They tend to develop cracks, which make them unusable.”
Why is it hard to print aluminum?
Normal aluminum melts at temperatures of about 700°C. The lasers in a 3D printer must raise the temperature much, much higher—past the metal’s boiling point of 2,470° C. This changes a lot of the properties of the metal, particularly because aluminum heats up and cools down faster than other metals.
In 2017, a team at HRL Laboratories, based in California, and University of California-Santa Barbara discovered a high-strength aluminum alloy that could be 3D printed. They found that adding zirconium to the aluminum powder prevented the 3D-printed parts from cracking, resulting in a strong alloy.
The NIST researchers set out to understand this new, commercially available 3D-printed aluminum-zirconium alloy on the atomic scale. “In order to trust this new metal enough to use in critical components such as military aircraft parts, we need a deep understanding of how the atoms fit together,” says Zhang.
The NIST team wanted to know what made this metal so strong. Part of the answer, it turned out, was quasicrystals.
How do quasicrystals make aluminum stronger?
In metals, perfect crystals are weak. The regular patterns of perfect crystals make it easier for the atoms to slip past each other. When that happens, the metal bends, stretches, or breaks. Quasicrystals break up the regular pattern of the aluminum crystals, causing defects that make the metal stronger.
The measurement science behind identifying a quasicrystal
When Iams looked at the crystals from just the right angle, he saw that they had fivefold rotational symmetry. That means there are five ways to rotate the crystal around an axis so that it looks the same.
“Fivefold symmetry is very rare. That was the telltale sign that we might have a quasicrystal,” says Iams. “But we couldn’t completely convince ourselves until we got the measurements right.” To confirm they had a quasicrystal, Iams had to carefully rotate the crystal under the microscope and show that it also had threefold symmetry and twofold symmetry from two different angles.
“Now that we have this finding, I think it will open up a new approach to alloy design,” says Zhang. “We’ve shown that quasicrystals can make aluminum stronger. Now people might try to create them intentionally in future alloys.”
Paper: A.D. Iams, J.S. Weaver, B.M. Lane, L.A. Giannuzzi, F. Yi, D.L. LaPlant, J.H. Martin, and F. Zhang. “Microstructural Features and Metastable Phase Formation in a High-Strength Aluminum Alloy Fabricated Using Additive Manufacturing.” Journal of Alloys and Compounds. Published online April 7, 2025. DOI: 10.1016/j.jallcom.2025.180281.
