Why Modern Electric Boilers Are a Safer Choice
Advanced electrode boilers reduce risk of explosion, fire, and noxious emissions associated with fossil-fuel burning units
Del Williams
Tue, 09/06/2022 - 12:02
In industry, gas-fired boilers have been the standard for decades to produce steam and heat process water. However, not all boilers are created equal in terms of safety. By definition, combustion-fueled boilers can emit harmful vapors, leak gas, and even cause explosions and fires.
In a recent example, a natural gas boiler was cited as the cause of a massive explosion and fire at a food processing plant in eastern Oregon that injured six and caused severe damage to the facility’s main building. Given the risks, many processors are turning to a new generation of electric boilers to dramatically reduce these hazards.
“With gas-burning boilers, any gas leak can increase the risk of an explosion wherever there are fuel lines, fumes, flames, or storage tanks,” says Robert Presser, vice president of Acme Engineering Products. “So, gas units must be continually monitored or periodically inspected.” Presser notes that state and municipal safety guidelines vary depending on boiler type and the expected frequency of inspection.
Why Remote Work Isn’t Working
ISO 9001:2026 Is Here
