How you communicate a message is as important as the message itself. When it comes to internal communications, this certainly holds true. Company culture can give your organization a major strategic advantage in these changing times. But what your culture consists of—goals, values, and practices—must be effectively transmitted according to best practices if employees are going to understand and act upon them. Therefore, it’s essential to focus not just on what you’re communicating but also how you’re communicating it.
The 18 internal communications best practices below can improve your internal communications strategy and get your team connected, engaged, and motivated.
1. Envision, strategize, and plan communications
“Good ideas need good strategy to realize their potential.”
—Reid Hoffman, founder, LinkedIn
What do you want internal communications to do for your team and your company? How will you get there? Where does your communication process stand right now, and what needs improvement? How soon would you like to reach your goals?
