Key Specifications That Determine the Accuracy of a Weighing System
How to ensure you achieve optimal weighing accuracy for your application
No matter what you're weighing... be sure it's cute
Joe Flanagan
Wed, 03/15/2017 - 12:02
There are many factors that influence the accuracy of a weighing system. Assuming that external factors are minimized or eliminated, the most important factor is the appropriate selection of the load cell for a given weighing application. This discussion covers the key load-cell specifications that are important to ensuring that you achieve optimal weighing accuracy for your application.
Nonlinearity
This specification is typically given in terms of a percentage of rated output or percentage of full scale. It represents the cell’s measurement error over the entire output range. Looking at a calibration curve for the load cell, the nonlinearity is the amount that the curve deviates from a straight line.
