LVDT Position Sensors: Connectors or Lead Wire?
When to use which
TE Connectivity
Tue, 08/04/2015 - 16:10
Connectors and lead wires provide the electrical connection between the coils of an LVDT position sensor and signal conditioning electronics. Choosing between a connector and lead wires, when specifying an LVDT or other sensor, often depends on the application and its environment.
Below are some helpful tips to guide you in deciding whether to specify a connector or lead wires for your next sensor.
Pros and cons of wire leads and connectors
Shown are LVDT sensors configured with connectors (left) and lead wires (right)
