Nanosensors Could Aid Drug Manufacturing
Arrays of carbon nanotubes can detect flaws in drugs and help improve production
MIT News
Thu, 08/22/2013 - 16:10
MIT chemical engineers have discovered that arrays of billions of nanoscale sensors have unique properties that could help pharmaceutical companies produce drugs—especially those based on antibodies—more safely and efficiently.
Using these sensors, the researchers were able to characterize variations in the binding strength of antibody drugs, which hold promise for treating cancer and other diseases. They also used the sensors to monitor the structure of antibody molecules, including whether they contain a chain of sugars that interferes with proper function.
“This could help pharmaceutical companies figure out why certain drug formulations work better than others, and may help improve their effectiveness,” says Michael Strano, an MIT professor of chemical engineering and senior author of a recent paper describing the sensors in the journal ACS Nano.
The team also demonstrated how nanosensor arrays could be used to determine which cells in a population of genetically engineered, drug-producing cells are the most productive or desirable, Strano says.
