Gauging fixtures are a staple in many metrology labs and assembly lines. They offer a fast, easy, and inexpensive way to determine if a measured part passes tolerances. Two popular tools that are found in many fixtures are HEIDENHAIN length gauges and linear variable differential transformers (LVDTs). Although LVDTs and length gauges are both used for the same purpose, the way they operate is fundamentally different.
Privacy Policy.
