(Pinpoint: Peabody, MA) -- Pinpoint Laser Systems, which designs, manufactures, and sells measuring and alignment tools and solutions, has released an improved version of its 4-Axis Precision Mount for the Microgage Laser line. It is lighter and has finer accuracy and control. It also has high-precision rollers slides.
The 4-Axis Precision Mount moves the Microgage Laser in four axes—vertical and horizontal, as well as two angular axes, pitch and yaw—to simplify machinery and equipment alignment tasks. The laser beam can be positioned to within 0.001 in. and is ideal for checking machinery travel, precision bore alignment, and the straightness of fixtures and assemblies. The mount is easy to set up and can be used on the production floor as well as in the field for installations and servicing work.
