(Meggitt Sensing Systems, San Juan Capistrano, CA) -- Meggitt Sensing Systems, a Meggitt group division, has announced the global market introduction of the Endevco model 4830A, a handheld, lightweight, battery-operated electronic instrument designed to simulate a variety of transducer outputs. The simulator offers a convenient and portable means of verifying instrumentation settings and cable integrity in aerospace and automotive test cells, as well as other in-laboratory and field testing environments.
Available output signals from the model 4830A include single-ended and differential charge (pC), single-ended voltage (mV) and current-sinking ISOTRON (IEPE). The further inclusion of a tachometer (TTL) output signal makes the unit a convenient and portable means of on-site instrumentation testing and servicing. Simulated outputs are available in either English or Metric units over an available frequency range of 1 Hz to 10 KHz, with an adjustable output amplitude of up to 10,000 pC or mV pk and with overall noise of <2 mV or 2 pC rms.
