(Hardy Process Solutions: San Diego) -- Hardy Process Solutions has announced an all-new Hardy Caseweigher series, fully automated checkweigher scale systems designed to continuously weigh larger items while in motion.
Flexible and highly accurate, the Hardy Caseweigher weighs products in containers such as cases of cans, bottles, rigid shrink-wrapped packages, bags, or pails. Featuring PLC control architecture and a large touchscreen HMI display, operators can easily navigate between different product recipes or adjust machine set-up parameters.
The heart of the machine, which delivers fast, accurate, and stable weight readings, continues to be based on Hardy’s HI 4050CW high-performance check-weight controller and a Hardy C2 load cell. The check-weight controller can communicate seamlessly both upstream and downstream across Rockwell’s Connected Enterprise network when built with either an Allen-Bradley CompactLogix PLC or via an optional EtherNet/IP connection when built with a standard PLC Platform.
