(Hexagon Metrology: North Kingstown, RI) -- Hexagon Metrology announced today the Leica B-Probe, an entry-level, wireless probing device which extends the capability of the Leica Absolute Tracker AT402. The handheld Leica B-Probe is designed for the inspection, alignment and assembly of large scale fabrications such as railway coaches, construction and off-highway vehicles or agricultural machinery.
The Leica B-Probe works within a 32.8 ft (10 m) radial distance from the AT402 with an accuracy of ± .0078 in (0.2 mm) over a full measurement range, offering greater capabilities and flexibility over similar systems that have fixed-base stations. The lightweight 6.7 oz (190 g) B-Probe features IP50 certification and is AAA battery-powered, an ideal complement to the ultra-compact, user friendly system design of the AT402. By using the move station method, the working range of the system can easily be multiplied with almost no loss in probing accuracy. For even larger parts or measurements that require higher accuracies, a standard retroreflector can also be used in combination with the B-Probe to take full advantage of the AT402’s accuracy and 525 ft (160 m) radial measuring range.
