(AMETEK: Largo, FL) -- The JOFRA ASC 301 portable process signal calibrator from AMETEK Test & Calibration Instruments provides the accuracy and functionality of a laboratory calibration instrument but is compact enough to fit into a toolbox or operate with one hand for easy field calibration.
The instrument’s robust housing makes it ideal for field service as well as workshop use, while its high-accuracy capabilities are designed to meet the demands of modern pressure sensors and temperature transmitters.
The JOFRA ASC 301 is more than a signal calibrator. Combined with a JOFRA APM external pressure module or a JOFRA dry-block calibrator, it is a multifunctional pressure and temperature calibrator. When used with JOFRACAL calibration software, the instruments can document as well.
