(Lenox Instrument Co.: Trevose, PA) -- Lenox Instrument Co. announces the addition of a new Portable Videoscope System to its extensive line of remote visual inspection instruments. Designed to meet the demands of the industrial inspection environment, the self-contained system combines state-of-the-art video technology, cordless operation, compact portability, and rugged durability at an affordable price. The Portable Videoscope System is well suited for inspection of bridges, drill pipe, turbines, airframes, power generation equipment, process tanks and vessels, tubing and pipes, heat exchangers, hydraulic cylinders, and other areas difficult to that require videoscope inspections.
Lenox Portable Videoscope System models offer a choice between two removable, waterproof, color CCD camera heads with built-in bright LED lighting—one is 1 in. (26 mm) diameter with 120° field of view, and the other is 1.5 in. (40 mm) diameter with 360° pan and 180° tiltable.
