(Marposs: Auburn Hills, MI) -- Marposs, a world leader in measurement, inspection, and test technologies, announces the availability of its Aeroel Wireline laser measuring system designed for in-line checking of drawn wire diameter and ovality. Wireline is a contactless gauging system well-suited for measuring steel wire for tires, copper wire for electrical cables, CO2 welding wire, and more. By enabling 100-percent inspection, it eliminates any risk of rejects or complaints, helping to improve quality, eliminate scrap, and reduce labor cost.
Using a dual-axis laser gauge, the Wireline laser measuring system checks the wire tolerance of the wire and stops the drawing machine when the die wear exceeds the pre-set limit. It counts the meters of wire being drawn and provides statistical reports for each spool.
The Wireline system is unaffected by wire vibration and speed, consistently delivering accurate and reliable measurements. It features a patented dust protective jacket that safeguards it from soap and iron dust, making it possible for installation on dry drawing benches.
