(Ocean Optics: Dunedin, FL) -- Ocean Optics has launched a spectrometer line that combines decades of miniature spectrometer design expertise with industry-leading manufacturing techniques. The Flame spectrometer delivers high thermal stability and low unit to unit variation without compromising the flexibility and configurability that are the hallmark of modular, miniature spectrometers. Features such as interchangeable slits, indicator LEDs and simpler device connectors provide great flexibility for a wide range of UV-Vis applications including OEM integration and lab, industrial and field use.
The Flame is fully configurable across the 190-1100 nm wavelength range for use in absorbance, transmission, reflectance, irradiance and color applications. Spectrometers come preconfigured or custom configured, with interchangeable slits that enable users to adjust resolution and throughput on demand. For example, the user can reconfigure the same spectrometer from high resolution for absorbance to high throughput for fluorescence in seconds. To further increase measurement power, the Flame works seamlessly with the Ocean Optics range of light sources, optical fibers, sampling accessories and software.
