(Advanced Inspection Technologies: Melbourne, FL) -- Advanced Inspection Technologies (AIT) introduces the INVU pipe camera. The INVU is a handheld video inspection system designed for industrial and commercial applications. It is a unique miniature push camera system, with the rigidness of a fiberglass push rod and the flexibility to easily get into the smallest of confined spaces such as heat exchanger tubes, HVAC systems, septic lines and tanks, boiler tubes, steam lines, conduit, process lines, and other applications that were previously impossible to inspect.
Made with highly durable material and a powerful internal system, the INVU is easy to use. Its unique 25 ft spring cable with a 1 in. diameter head allows you to quickly inspect pipes with multiple angles. The INVU pipe camera weighs in at only 3.2 kg (7 lb) and can snake through incredibly small access areas—as small as 25 mm (1 in.). Inspectors no longer need large cable reels or bulky cases to transport the system.
