(Ametek: Largo, FL) -- The new JOFRA hand-held pressure calibrator from AMETEK Calibration Instruments offers electrical generation of pressure or vacuum with the touch of a key. The calibrator features a unique built-in electrical pump system. No manual pump required.
The versatile HPC600 is a true multifunction solution offering features and functions that make it ideal for a wide range of high-accuracy pressure calibration applications from simple tool type jobs to complex custody transfer systems.
The multifunctional HPC6000 is designed to work as a pressure indicator, pressure calibrator, a complete mA loop calibrator (including 24-volt supply), a voltmeter, a thermometer, and a pressure/vacuum generator. All are in a single rugged housing with an easy intuitive operating system that fits in the palm of the hand.
The HPC600 features a user configurable information display, 15 different pressure units, transmitter supply, mA input/output, percentage error calculation, voltage measurement, serial communications, and an external pressure module capability. The accuracy of the HPC is specified in percentage of reading to ensure accuracy and more applicable pressure range.
