(EASI: Milford, MI) -- Electronic Applications Specialists Inc. (EASI) announces a pneumatic gauge system that makes dimensional air gauging easy. Our new air electronic converter (AEC) has many advantages over other air gauging systems.
- Repeatable linear measurements from zero clearance to 0.010 in., single jet (0 to 0.020 in. for diameter)
- Measurements can be made with short bursts of air (e.g., 1 second) to save compressed air.
- It can operate from 10 psi for small clearances to 50 psi or more for larger clearances.
- It is available in single outlet and dual outlets for differential complex measurements.
- Single master calibration (no air flow equal to zero clearance dimension)
- Simplified tooling design and machining (no undercuts or grooves)
- The basic model operates from 5 VDC and outputs a zero to five volt signal.
- Pulse width modulated output is standard in basic models.
There are none of the inconveniences of existing gauging systems, such as:
- No confusing adjustments to change
- No precision or adjustable orifices that could get clogged
- No bleed or balancing circuit that can waste compressed air
- Negligible pressure drop in the measuring circuit
- No need for precise pressure regulation
- No moving parts
Models will be available to provide direct replacement for our 1-AEC and 2-AEC. New models with 16-bit serial outputs are coming once bus structure and coding are defined.
Customer input is welcome on this air gauging product or for suggestions on any of our products. Please e-mail Michel Dechape, president EASI, at mdechape@e-a-s-inc.com, or call (248) 685-8283.
