(E Instruments: Langhorne, PA) -- The SignalCal 2 T/C from E Instruments simulates voltage and thermocouple readings for calibration purposes. The device is rugged and easy to use, measures eight types of thermocouples (R, S, B, E, K, J, T, and N), and has an accuracy of ±0.05 percent. The SignalCal 2 T/C includes:
The ability to select a Temperature Output Range in °C and °F
A new 9 V battery with an estimated battery life of 25 hours
A dc voltage output range of 100 mV or 1 V
A measuring function that allows for an input range of -10 to 110 mV
An easy-to-use operator panel with an easy-to-read LCD display
An automatic power-off feature, which turns off the unit in 10 minutes if not used
A low-battery display symbol, so you know when to change the battery
NIST traceable calibration certificate included with every unit
For more information, visit www.e-inst.com
