(Suburban Tool Inc.: Auburn Hills, MI) -- Suburban Tool Inc., a well-known manufacturer of high-precision, high-quality tools for toolmakers, announces this addition to its line, the SineSet System.
The SineSet System is comprised of a series of SineSet compatible accessories that can be bolted directly to Suburban sine plates, compound sine plates, and 90° conversion plates to create complete working systems.
Starting with a sine plate, quickly add and remove a magnetic chuck, precision vise, precision angle plate, vacuum chuck, Master-Grind spin index fixture, and more, knowing that each accessory will be perfectly fit and aligned each and every time.
The SineSet System:
• Saves time and money
• Gives you the competitive edge
• Allows quick setups
• Requires less investment in tools
• Eliminates clamping
• Needs little or no indicating
• Enables an almost limitless number of tool combinations
All tools can be used independently or as a sine system.
About Suburban Tool Inc.
Suburban Tool Inc. has more than 50 years of experience in manufacturing the highest quality work-holding products and inspection equipment for thousands of satisfied customers from the smallest operations to the largest corporations!
A significant part of Suburban’s quality is due to its experienced craftsmen adhering to precision standards. Suburban’s products are manufactured by using exacting procedures.
Suburban Tool Inc. proudly manufactures products in its 70,000 square foot world headquarters Auburn Hills, Michigan.
Contact sales:
Suburban Tool Inc.
4141 N. Atlantic Blvd.
Auburn Hills, MI 48326
Phone: (248) 391-7800
Fax: (248) 391-7462
Email: tools@subtool.com
https://www.subtool.com/
