(Spectronics Corp.: Westbury, New York) -- Spectronics Corp. has introduced the OPK-300N OPTIMAX Multi-Lite NDT Inspection Kit that features a super-powerful, multi-LED flashlight. Its lightweight, cordless, ergonomic design allows NDT technicians to engage in a variety of lengthy, fatigue-free applications in the field or workstation.
The OPK-300N kit features three Qwik-Connect interchangeable LED lamp heads that connect to the flashlight. Providing single-wavelength illumination in UV-A (365 nm) and blue light (450 nm), it’s perfect for both prescreening of fluorescent particles in ambient light conditions and for more complex NDT inspections using magnetic particles or fluorescent penetrants. In addition, a convenient white light LED helps illuminate dark work areas.
The OPTIMAX Multi-Lite produces a nominal steady-state UV-A intensity of 18,000 µW/cm² and a blue-light intensity of 7,000 µW/cm² at 15 in. (38 cm). Its Electronic Intensity Stabilizer guarantees consistent performance; the beam will not weaken between charges. Powered by a NiMH battery, the flashlight provides 90 minutes of continuous inspection between charges. It meets ASTM UV-A intensity specifications for FPI and MPI.
