Wireless Vibration and Temperature Sensor for Superior Machine Monitoring
Reduce labor costs by eliminating manual checks and risk of human error
Banner Engineering
Thu, 07/02/2015 - 11:50
(Banner Engineering: Minneapolis, MN) -- Banner Engineering introduces its wireless vibration and temperature sensor, Designed to effectively monitor machines for increases in vibration and temperature, the sensor measures RMS velocity in inches per second or millimeters per second, and temperature. This enables the sensor to identify machine problems before they become too severe and cause additional damage or result in unplanned down time.
The sensor is optimized to work with 1-wire serial radio devices, such as Banner’s wireless Q45VT Node, the P6 Performance Node, and the MultiHop M-H6 radio. Operators can easily set vibration thresholds based on the ISO 10816 standard. When a threshold has been exceeded, the wireless node can provide local indication, send the signal to a central location, and send the vibration and temperature data to the gateway for collection and trending.
