(ZEISS: Maple Grove, MN) -- ZEISS Industrial Metrology has introduced of the new DuraMax LTE coordinate measuring machine (CMM), providing uncompromising access to ZEISS scanning technology at an affordable price.
Equipped with the same controller technology, software, and VAST sensor technology available in larger ZEISS systems, the CMM’s specifications, small footprint, and no need for compressed air make it ideal for manufacturers with smaller inspection labs.
“The DURAMAX LTE is an easy-to-use and affordable measuring solution with trusted ZEISS scanning technology,” says David Wick, Bridge CMM product manager at ZEISS Industrial Metrology. “The field-proven VAST XXT scanning sensor provides reliable measurement results, scanning hundreds of points per second to gather the data needed to provide accurate results. The 500 × 500 × 500 mm measuring volume on a machine that needs only 1,100 × 1,400 mm of table space, and no shop air is perfect for manufacturers trying to maximize their inspection lab space.”
