![](/sites/default/files/editorial_images/construction640.gif)
Producing quality work is imperative in every field, particularly in the construction industry. A well-built structure, whether it’s an educational facility, hospital, or a commercial establishment, provides shelter, safety, and stability, which is why quality should always be a top priority. As soon as a construction project begins, it’s every project team’s intention to provide quality services. An established quality plan in construction that uses lean principles leads to more reliable outcomes.
Various obstacles can occur at any time during a project, especially in the planning and construction phases, causing disruptions in plans. These types of interference can lead to unforeseen delays, expensive rework, and long-term ramifications for the client if quality issues compromise building integrity. In fact, a study conducted by Frontiers in Engineering and Built Environment discovered that poor quality can increase the cost of a building by more than 50 percent and can cause up to 50 percent of project delays.
